1650 Oliver
Bacman
02-28-2002 07:51:21
1650 diesel noise around two-speed stops when clutch is pushed in. On a hard pull the hood & cowling shake to the point of breaking. Any help is appreciated. Thanks.
Bacman
jim b
02-28-2002 18:27:56
 Re: 1650 Oliver in reply to Bacman, 02-28-2002 07:51:21
we would check the plate on the back of engine for cracks. next check to see if sprockets are level with each other. if not you may have to shim the rear of engine. some later models have a bolt thru the frame that will push up on the hydra power to give it some support, however you want to get the alignment close before you use the bolt.
i hope this helps.
davidrladuke
03-03-2002 04:44:13
 Re: Re: 1650 Oliver in reply to jim b, 02-28-2002 18:27:56
what is a 1969 1650 diesel worth good rubber frontend loader paint fair less than 1000 hours on rebuild know the tractor as it is my neighbor just dont want to pay to much needs clu
Larry
02-28-2002 09:20:48
My first guess would be the coupler chain and sprokets between the trans. and two speed.Allso the engine maybe miss allined the bolts maybe out or the bolts that hold the trans. to the frame maybe loose.
