70 Rear housing crack
KEN
02-27-2002 19:56:11
I cracked the rearend housing on 1941 70 RC. Are all rear housing the same for the 70 including the Standard . Or were there Diff. set ups beside the 3 gear and the 5 gear? Kinda need one. Ken
Ryan Eslick
03-12-2002 19:49:47
 Re: 70 Rear housing crack in reply to KEN, 02-27-2002 19:56:11
At the time i am restoreing a 1939 oliver 70 rc, and i am useing a some what newer oliver 70 as a parts tractor. i noticed that the rear axle housings are different, the axles are heavier, the bull gears havea different design, as far as the main case, i am not sure if the are the same. we did notic the part number on the 39, but didn't see the part number in the same place on the parts tractor. i am located in central iowa, i would consider this piece off my parts tractor to be scap iron, if u tell me how your broke yours, you can have this one so i can get rid of it. ( no charge)
jerry gerthofer
03-01-2002 18:50:47
boy that little stunt will cost you a little time and money. housings were all the same on them..
