Why won't 60 get gas
Geoffrey
02-27-2002 07:43:20
I am hveing trouble starting my 60. I know it has spark and compression, so it must not be getting fuel. The pluge don't even get wet after quite a while of cranking. The thing that gets me is I just overhauled the carb not more than 10hrs ago and it ran fine so far. Could the float be stuck up and have the valve shut off? Would it help if when I'm done with it, to shut off the gas before shutting the tractor off?
Thanks,
Geoffrey
gari khan
10-05-2002 02:56:17
 Re: Why won't 60 get gas in reply to Geoffrey, 02-27-2002 07:43:20
hello dear Gulab where are you i love you ?
RAB
02-28-2002 12:43:26
So have you tried opening drain on carb with fuel line shut off? If fuel runs out and then continues at a good rate when fuel is turned on further back up the line, then its not the float or float valve sticking closed.
Don't know whether valve is attached to float on your carb - it is on 80/90. If its not it could stick until the engine starts and then operate satisfactorily (with plenty of engine vibration)
Did you use a new gasket? or maybe the gasket is too wide and just rubbing on the float?
Can't really tell but hope these suggestions may help. Regards, RAB
Geoffrey
02-28-2002 19:56:24
 Re: Re: Why won't 60 get gas in reply to RAB, 02-28-2002 12:43:26
I never thought about the gasket restricting the float.
Thanks for the help guys!!
Geoffrey
02-28-2002 07:08:01
I know it is getting gas, it has to be in the carb.
Ben Haag
02-27-2002 16:05:36
i have 3 oliver 60's and i know that if u unscrew ur sediment bowl from the tank, it will be all plugged up with garbage.. After u clean it out blow thrught the line, then rip apart an old speaker magnet and hook it to a piece of wire and drop it down it,, just let it sit there all the time, the wire is thin enough that you can screw ur gas cap back on..
Ben Haag
02-27-2002 16:05:33
John P.
02-27-2002 15:56:43
Before you dive into the carburetor, make sure you are getting gas out of the tank. My tank had rusted up and had plugged the fuel petcock with chunks of rust. I wound up having to remove the tank and have that RENU epoxy treatment done to it.
Larry
02-27-2002 09:08:15
You should have a carborator drain plug,take that out and see if gas keeps running out.If not Then unhook fuel line and blow open needle valve.
jerry gerthofer
02-27-2002 10:17:52
 Re: Re: Why won't 60 get gas in reply to Larry, 02-27-2002 09:08:15
must be needle and seat.stuck or binding....
