550 Cockshutt worth a 1000?
cart
02-27-2002 06:28:20
Got a line on a 550 CS with a bale fork, hydraulics are strong, tires checked,runs good and is dry.Previuos owner,a friend said the tractor was good,only sold it 10 months ago. I'm surely tempted.
jerry gerthofer
02-27-2002 10:21:42
 Re: 550 Cockshutt worth a 1000? in reply to cart, 02-27-2002 06:28:20
sure it,s worth $1000.00 bucks.....
Mike (WA)
02-27-2002 08:36:02
You don't indicate whether its a "Cockshutt" Cockshutt, or an "Oliver" Cockshutt. There was a model 550 in each line- the "genuine" item is more of a row-crop model, with Hercules engine, while the Oliver is the same as a 550 Oliver- a utility tractor about the same physical size as an 8N Ford. The Oliver version is worth more, but both are good tractors and certainly worth the money.
Canada Grant
02-27-2002 09:03:13
 Re: Re: 550 Cockshutt worth a 1000? in reply to Mike (WA), 02-27-2002 08:36:02
I have both , cockshutt and oliver and run both for many years both good tractors both worth the same to me [priceless!]
ShepFL
02-27-2002 10:58:51
 Re: Re: Re: 550 Cockshutt worth a 1000? in reply to Canada Grant, 02-27-2002 09:03:13
SPRING has sprung here in FL. Will be down to 8 tonite and tomrow.
Check out Tractor forum for pic of the Upick. Still don't have my 4340 here yet :(
ShepFL
02-27-2002 07:44:03
If I was you I would SNAP it up immediately if in any kind of shape at all. The 550 is an extremely popular utility tractor. Prices keep climbing N.
If you don't want it drop me a line, I would be interested if is a Dsl. Need a stablemate for the Oliver 550.
rem
03-03-2002 08:35:18
 Re: Re: 550 Cockshutt worth a 1000? in reply to ShepFL, 02-27-2002 07:44:03
Hi,
Buy it!!
I've owned a number of cockshutts and the 550 is a very powerful tractor for it's size. The 550 with the herc when tested in Nebraska was one of the strongest pullers, ever. It was the strongest tractor I've ever driven for it's size. It is worth much more than 1000 georges.
Good Luck,
cart
02-27-2002 11:36:28
Thankyou for your replies. I should have made myself clearer, its a Cockshutt with a 198 cid Herc gas engine, no PS. It sounds like its worth it.
