Oliver 88 Engine
Oliver88Puller
02-25-2002 07:12:07
I'm looking at an engine rebuild for an Oliver 88 puller. I would like to know what parts swap in and out of an Oliver 88 block---like a Super 88 crank, different heads, manifolds, etc. I'd like to bump up the displacement from the original 231 to somewhere close to 300. Thanks for the info.
BIGBAD 88PULLER
03-11-2002 17:56:47
 Re: Oliver 88 Engine in reply to Oliver88Puller, 02-25-2002 07:12:07
hey,buddy ..ILL TELL YA RIGHT NOW THAT(VISION MACHINE)IS FOOL OF IT !!!THAT GUY HAS TA BE A DUMB ASS!!YOU CAN ONLYGO 3 7/8 WITH THE SLEEVES!!ANY MORE AND THE BLOCK REQUIRES BOREING!!FOR 550$GET M&W PISTON KIT!!37/8.IT GIVES U 285 CI!!YA WONT EVEN HAVETA TAKE OUT THE CRANK!OR BORE IT!!YA JUST CHANGE SLEEVES!!!DONT BUY THOSE MANIFOLDS OFF OF (TRAVIS)THAT GUY HAS TA BE GAY!I ONLY PAID 250 FER MINE!!I AGREE WITH THEM THOUGH, IT IS HOW MUCH YA WANT TO PUT IN IT!!!YOUR BEST BET IS THE MANIFOLDS,A 1750 DRILLED OUT CARBURATOR,SHAVE YOUR STOCK HEADAND PORT AND POLISH IT,BORE IT !!!!DONTWASTE YOUR TIME WITH AN S88 CRANK!!IF YOUR GOING TA DO THET THEN GO GET A 1650 CRANK AND HAVE IT TURNED!!!GOOD LUCK!!FEEL FREE TO E-MAIL ME WITH QUESTIONS!!I HAVE ALREADY BUILT A PRO-STOCK 88 AND THIS WILL BE MY FIRST SUMMER RUNNING THAT ONE!!!!! TA TA
HOOKN88
03-12-2002 11:01:59
 Re: Re: Oliver 88 Engine in reply to BIGBAD 88PULLER, 03-11-2002 17:56:47
I COULDNT AGREE MORE WITH THE BIG BAD 88 PULLER.IF YOU DO THAT YOU OUGHT TO HAVEAROUND 80hp,give or take???BUT IF YOU STROKE ,YOU WILL REALLY GET THE HP.LIKE BIGBAD88PULLER SAID,,WHEN YOU STROKE IT STROKE IT BIG!!DONT USE A S88 CRANK!GET A 1650,CRANK AND HAVE IT STROKED,,ALSO GET IT POLISHED AND BALANCED!!!!IF YOU DO THAT THEN BORE IT OUT TO 43/8!THIS WILL COST YOU BIG THOUGH?BEST BET IS TO BUILD A GOOD DIV.2 TRACTOR OR A GOOD PRO STOCK!IT WILL COST LESS AND NOT BREAK DOWN AS MUCH,AND YOU WIL HAVE THE SAME FUN!SEE YOU AT THE PULLS!!!!! !!!!! !!
vision machine
02-26-2002 08:00:07
If you want to get up to 300 cubic inch , i would take a super 88 sleeve and take it to a machine shop and bore the inside of the sleeve out to 4". then get a automotive piston and put in there. This boring of the inside of sleeve will not requiire any boring of the block. You will then need to get your cam reground to get more lift. and if you wanted to you could also put a set of 4020 rockers on your stock 88 shaft and put the 88 adj. screw in them. that should give more lift yet. I would just use stock valves in cause you arent that much cubic inch to put big valves in. But go to a machine shop and get a three angle grind job on them valves. Also take it to a machine shop and have them mill the port holes out in the head i wouldnt go past 1.45" on either exhaust or intake. I would also go get a aftermarket 88 exhaust manifold and port it out a little bit but not to much. I would also get a 1650 intake manifold it has bigger holes where the carburator bolts up. port that intake manifold out also and port the hole from where the carb goes up on the manifold out a little bit. i would put on a carb off of a John deere 6600 gas combine. Or one off a John deere 4030 gas is the same thing. that is a good carb and you will have to tune it a little to get max horsepower. If it is a rebuild on the old motor i would also put in new main & rod bearings. and have the crank cheaked. Also a hot coil would do you some good also i would reccomend about 45,00 - 60,000 volt and also if you wanted to you could put a msd box on also. make sure you have some good quality spark plug wires. and get your distributor recurved wouldnt hurt either . hope this helps ya
larry h
02-25-2002 16:54:50
most people are putting 310 engines out of 1850s in them or putting the heads with hopped up pistons really depends on how much cash you want to spend runs from 2000-10000
Travis Most
02-25-2002 08:33:12
A good head to use would be a head off of a 320 c.i. Waukasha engine. I have one for sale off of a Waukasha power unit. It has alot bigger valves and ports. It bolts right on to a 88 block. I also have the int/ex. manifold for it. We are asking $800 for the head-complete with valves, and $300 for the manifold. Let me know what you think- (715)262-5156
