70 Rear housing
KEN
02-24-2002 08:41:56
I cracked the rearend housing on 1941 70 RC. Are all rear housing the same for the 70 including the Standard . Or were there Diff. set ups beside the 3 gear and the 5 gear? I have found a 1936 or 1937 unstyled will it work? Thanks Ken
COWBOY
02-27-2002 14:38:49
 Re: 70 Rear housing in reply to KEN, 02-24-2002 08:41:56
I have changed the rear in my Industrial 70 with a Row Crop 70. The only diffrence is that the Ring/Pinion are of a higher ratio in the industrial and standard ones, and a lower ratio in the Row Crop version due to tire size.
If it is a split 3 speed trans (6 forward, and 1 reverse gears) the housings should be the same. Just the guts are diffrent.
You can see my Industrial 70 at http://www.ainop.com/users/cowboys.airranchtwo and go to the Restoration pages.
John holcomb
02-24-2002 15:45:19
Hi, I have about 15 out here and can see no difference from the 3 or 5 gear or the standards.
