Oliver OC4 rear rt sprocket/gear/bearing
gary
02-23-2002 19:34:52
Looking at buying an OC4. Starts good, but rear sprocket or bearing or gear locks up and makes clunking sound. any idea what's wrong and what it might take to fix it? Parts availability prefer Pacific Northwest?
polk crawler
02-25-2002 08:15:31
 Re: Oliver OC4 rear rt sprocket/gear/bearing in reply to gary, 02-23-2002 19:34:52
Can't help with the OC4 problem but have an OC3 in process of repair etc. I do not find many in PNW appearing on any board discussing crawlers in particular. I am located near Salem, Ore: would be interested in knowing your location. Thanks PC
jerry gerthofer
02-24-2002 09:25:49
you sure the studs are not loose or broke that hold the sprocket on..... is a easy fix...there are parts out there for thes
