Oliver Super 225 power unit ?
m kuhns
02-15-2002 17:10:59
My step father called me tonight from a sale that he attended to in Florida. He saw an Oliver Super 225 power unit with a water pump on the rear of it. The unit had oliver sheet metal on top of it and and oliver grill. An Oliver data plate was attached to it also. Serial# reads 91-615-009 The last zero in 009 might be a nine. Spec# 12-0012
The engine was a six cylinder diesel with indirect injection and had Oliver printed on the intake manifold. This engine is larger than the 310 waukesha used in the 1950. Does anyone have any idea what engine might be in this power unit? I'm assuming it is a Waukehsa. What HP and how many cubes does it have? I'm guessing around 500 cubic inches and 150hp. Is this unit rare or not? My stepfather has a chance to buy it for $700 by Monday. Any help or comments would be greatly appreciated.
B A Star
02-16-2002 21:31:16
 Re: Oliver Super 225 power unit ? in reply to m kuhns, 02-15-2002 17:10:59
Super 225-D Oliver Power Unit, had a bore of 4 5/8" and stroke 5 1/4" for 529 Cu In. Was Diesel only, weight was 2344# with enclosure. It had a rated operating speed of 1200 with 15:1 compression ratio. Rated Brake horsepower: Max 130, intermittent, 111 and condtinous 100.
B A Star
02-16-2002 21:30:40
Eric the Red
02-16-2002 13:21:46
I would jump all over that for 700 if I were you. That would be neat to have and I imagine rare. Were in fl is it located.
Gary
02-15-2002 17:52:34
I believe these units had a hercules DRXB diesel which was the same motor that was used in the DD crawler
