Oil in 70 brake
KEN
02-11-2002 16:13:25
I just removed the cover on my brake and it has a lot of oil in it how do you get the hub off to replace the seal. Ken
COWBOY
02-12-2002 18:40:27
 Re: Oil in 70 brake in reply to KEN, 02-11-2002 16:13:25
It isn't to hard to remove the Drum to replace the seal,... The drum is held on by a Big Nut/Bolt with a Hex center. You can use a big bolt and weld a flat piece of steel to make a wrench or get a really big allen wrench. Don't forget to bend away the locking washer if it is still there.
The drum will just slide off then, and you can use a prybar to remove the seal, then install the new seal with a small hammer by tapping it in evenly. Install the drum, licking washer, nut and bend the locking washer over, and your ready for the brakes and cover.
