77 year parts needed
Geoffrey
02-09-2002 20:51:41
What year did the 77 row crop come with a brass clutch pedal. Does anyone have the narrow front axle for a 77? All I need is the axle itself, not the casting.
oliver farmer
02-27-2002 01:46:41
 Re: 77 year parts needed in reply to Geoffrey, 02-09-2002 20:51:41
what do you need? you say you don't need the cast housing, just the inner verticle shaft or just the spindle that the hubs go on? if your tractor doesn't have power steering, you can change just the lower spindle. i have a front end assy for a 77. not sure what year, but can check. the spindles are rusty as there is no hubs on them.
oliver farmer
02-27-2002 01:44:20
Jeff
02-10-2002 02:14:34
Geoffrey, is it a brass or bronze clutch pedal? I don't know what years exactly they put them on, I believe they were experimenting with them. My 1950 77 has bronze brake pedals and equalizer, and throttle lever. Jeff.
Geoffrey
02-10-2002 07:38:24
 Re: Re: 77 year parts needed in reply to Jeff, 02-10-2002 02:14:34
Maybe it is bronze. I haven't seen the tractor and was told it had that clutch pedal. I know ny grandpa's 66 has that kind of throttle lever.
thanks,
Geoff
