Hard starting 88
new to Oliver
02-09-2002 10:01:27
I have an 88 diesel. she blows a little white smoke and wont start without a little shot of ether. even when its warmed up good it still doesnt like to start. Any ideas? Thanks for the help
Shadetree
02-10-2002 18:19:12
 Re: hard starting 88 in reply to new to Oliver, 02-09-2002 10:01:27
Most likely your tractor is getting weak on compession due to the fact that it has probably been started using ether for a long time. However I would first make sure that the batteries and starter are both in very good shape because a diesel has to spin just over 400 rpm to get a good start. Some times jumper cables help but a slow starter may prevent the engine to start even with the added help to the batteries. Also your injectors could also be checked to make sure they are popping off at the right pressure and atomizing the fuel properly which can also contribute to a hard start. An engine overhaul would be the last alternative due to the expense. Good Luck Shadetree
