S55 hand start?
Bill in the Sou
02-02-2002 15:56:16
I just got the manual for my Super 55, and see that it's made to accept a hand crank starter. It needs "jaws" and the crank itself. I like the idea of having this as a backup. Anyone know where I could get these items, or info on how to make them myself? I appreciate the help. This is a great site with great folks! thanks! .
John P.
02-02-2002 17:57:42
 Re: S55 hand start? in reply to Bill in the South, 02-02-2002 15:56:16
Oliver never intended the use of a hand crank to start this tractor and the manual states so. Its only intended use was to turn the engine over for maintenance. Quickest way to a broken arm that I know of.
Kevin
02-02-2002 16:21:30
Sounds like a great way to break your arm. When 30 HP decides to hit 400 RPM I wouldn't want to be holding on to a hand crank!
RAB
02-04-2002 12:28:43
 Re: Re: S55 hand start? in reply to Kevin, 02-02-2002 16:21:30
Some of us don't have the option. My 50 horses is properly timed and doesn't give any problem - anyway only about twelve horsepower? as it would only kick back on one cylinder! You should be able to start any gas tractor on a handle as long as it doesn't fire before TDC at cranking speeds.
You just have to have a proper dog, only lift the handle, keep thumb on the same side of handle as your fingers and not stand where the handle can hit you! Can be d.....d hard work if it floods or if it's just a bad starter. RAB
