Position or Negative Ground?
John
02-02-2002 15:56:12
I have a 88 gas tractor which was converted to 12 volt before I got it. I thought it was positive ground but when I recently took the battery out to charge it, I discovered it was negative ground. Is there anyway to tell from the wiring what it should be? The ampmeter shows it is charging. Tractor runs good. The tractor has a generator. Any help is appreciated.
John
02-03-2002 07:55:23
 Re: Position or Negative Ground? in reply to John, 02-02-2002 15:56:12
Thanks for the information.
Jake
02-02-2002 21:53:36
If the conversion was done using an alternator it will be a negative groung, if it was showing charge it's charging system is correct.
Delbert
02-02-2002 18:12:26
The 88 oliver is pos ground,if it has been changed to neg ground turn the bat one half turn in the box and reconnet the cables and switch the wire's on the amp meeter terminal's. Some regulators are marked for pos or neg ground so check on the under side change regulators if necessary. The coil wires should be changed to the correct polairity although it probably will work either way. My 88 was changed to 12 volt berore I bought it. It was changed to neg ground, after several years I changed everything back to Pos ground, it starts better and sems to run better. If you have questions Email me. Hope this helps. Delbert
