Oliver 880 clutch/flywheel
ed
01-31-2002 10:33:25
hi , folks have a oliver guy working on my 880 deisel putting in new clutch. here is the problem he feels that with the new clutch the pedal is still not going to have enough travel. he thinks that the fly wheel has been turn down to far in the past. we need to know if anyone can tell us what the flywheel thickness would have been new. so he can compare it with the thickness now .....any help, suggestion, comment welcome..thanks in advance ..... ed
Larry
01-31-2002 14:27:24
 Re: oliver 880 clutch/flywheel in reply to ed, 01-31-2002 10:33:25
Thats rediculas there is plenty of adjustment either in the rod or the adjustment nuts on the clutch.He needs to check for worn keys in the shaft or other parts not the flywheel.
ed
01-31-2002 14:38:56
 Re: Re: oliver 880 clutch/flywheel in reply to Larry, 01-31-2002 14:27:24
larry, thanks for the come back passed on the info,he claims that he had already check into those. and everything was fine. what do do you think?..thanks ed
Larry
02-01-2002 09:53:42
 Re: Re: Re: oliver 880 clutch/flywheel in reply to ed, 01-31-2002 14:38:56
The most common thing I see is someone puts a new throwout bearing on a worn holder.The new bearing slides back too far to engage.If someone has put the newer style clutch parts on then the preasure plate its self may need the fingers adjusted to the rear a little.
ed
02-04-2002 06:21:35
 Re: Re: Re: Re: oliver 880 clutch/flywheel in reply to Larry, 02-01-2002 09:53:42
larry ,thanks will let you know thw out come..... ..ed
