550 charging problem
rwh
01-27-2002 15:36:42
My 550 gas has developed a charging problem. Charges OK at low rpm, poops at at higher speed. I replaced the wire harness and put on a new fan belt, which helped, but it still doesn't get enough juice when the throttle is opened. It has the original positive ground and generator. Seems to be worse when loader is in operation--could the hydraulic pump be bogging down the generator?
Paul Stanley
01-27-2002 20:22:14
 Re: 550 charging problem in reply to rwh, 01-27-2002 15:36:42
The improvement with the new belt might be a clue. If it is new, make sue that it doesn't need readjustment. Should be done after 10 hours of operation and as required. Make sure it isn't too lose. It only should have 1/2" of deflection. Another thing, check to see that the brushes aren't sticking.
By the way, did you put a meter on your system to get this diagnosis, or was it the battery wan't charging back up?
rwh
01-28-2002 08:11:22
 Re: Re: 550 charging problem in reply to Paul Stanley, 01-27-2002 20:22:14
Amp light comes on as rpm increases. Killed the old battery in about 15 minutes running.
Larry
01-28-2002 15:02:04
 Re: Re: Re: 550 charging problem in reply to rwh, 01-28-2002 08:11:22
If you have the power steering pump mounted to the generator it can lock up and slow the generator so it wont charge.There should be lots of belt sqeeling if this is happening.My guess is you have more and other problems.
Darryl J. Polak
01-30-2002 05:30:26
 Re: Re: Re: Re: 550 charging problem in reply to Larry, 01-28-2002 15:02:04
regulator coil springs are weak and turning off on throttle
