Super 55 PTO questions
Jeff
01-26-2002 23:54:32
I'm having trouble getting the PTO on my '57 Super 55 gas to engage. This has the lever by the seat that goes towards the rear to engage. The problem is that it doesn't want to go past "center" to stay engaged. I've got a shop manual for it now but it says nothing about this, only how to adjust if your clutch is slipping- with that spinner nut accessed through the inspection hole. What actually makes it go past center? Is it the links that pivot when the lever is moved? The links look like a bike chain link. Any help would be great. Thanks, Jeff.
Jake
01-27-2002 04:32:52
 Re: Super 55 PTO questions in reply to Jeff, 01-26-2002 23:54:32
When pulling the lever to the rear it will come to a stop and at that point the links [that are seen from the undersides] will be extended, the lever will require about 35 pounds more force to cause the toggle to break and lock the discs and send power to the rear. Don't forget to grease the PTO release bearing every 5 hrs, the fitting is on the right side below the break pedels. These are brass castings and a pain to replace. Good luck.
