Power steering
not convinced
01-25-2002 05:29:18
88 super calls for type a . I went to the white dealer he does not have it, but thinks any good grade is ok. What do you who have an old oliver with power use?? thanks..... ..... ..... .
Bob Stites
01-25-2002 17:45:37
 Re: power steering in reply to not convinced, 01-25-2002 05:29:18
When I had the same question, I went to the Texaco Web site. Following is the reply from the engineer, followed by my original question.
Dear Mr. Stites:
Havoline Automatic Transmission Fluid MERCON�/DEXRON�-III is a multipurpose
product that can be used for all GM transmissions requiring DEXRON�-III
fluids, as well as those previously specifying DEXRON� or earlier Automatic
Transmission Fluids: including DEXRON�, DEXRON�-II, DEXRON�-IIE, Type A and
Type A Suffix A Fluids, as well as Ford transmissions where MERCON� fluids
are specified.
Thank you for your interest in Texaco products.
Richard Moore
Staff Engineer
Equilon Enterprises LLC
Lubricants - Technical Information Center
1-800-782-7852, Option 3
> -----Original Message-----
> From: Bob Stites [SMTP:[email protected]]
> Sent: Sunday, August 12, 2001 10:55 AM
> To: [email protected]
> Subject: Type "A" transmission fluid equivalent
> > I have an 1964 tractor with a hydraulic system that is intended to use "automatic transmission fluid, type A". That product is no longer
available (at least I can't find it). What is available today that will serve this purpose?
The tractor is an Oliver 550, equipped with an Oliver 588 loader. It is the loader hydraulic system I need to maintain. Thanks,
Bob Stites
Also please note: The Operator's Manual specifies a mixture of engine oil (SAE 30 above 32 degrees, SAE 20 below) with a quarter cup "additive 102 082-A" per quart of oil. I have been told (but cannot verify) that 80/90 oil can be used in place of the additive.
Shadetree
01-25-2002 06:56:31
Not Convinced Dextron III I believe takes the place of type A oil. You see type A oil evolved into dextron oil, then dextron II, and now Dextron III. Also Type 55 Hydraulic oil can be used which is a 10wt. nondetergent hydralic oil sold by White. The oil has to be very fluid because of the small resivoir and a vain type of oil pump in the power steering pump. I hope this helps Good Luck Shadetree.
