Need help with Super 55
Jeff
01-20-2002 14:53:12
Does anyone know what the cause of the engine having to run with the choke on would be? Just rebuilt the carb with a rebuild kit. It won't keep running without the choke on a little. I tried adjusting the idle and power adjusting needles but they don't seem to help. Any help is appreciated. Tractor is a '57 gas. Thanks.
RustyHulk
01-20-2002 20:57:07
 Re: Need help with Super 55 in reply to Jeff, 01-20-2002 14:53:12
I had this problem with my Super 55. It was a manifold leak. Fairly easy to check with wd-40 sprayed around manifold/block junctions while running. RPM speedup indicates leak. Gaskets are available for about $15. Just take your time with the manifold bolts, and have a machine shop true up the manifold (35-40 bucks here). Good luck. The 55 is a great tractor. Rusty
Jeff
01-22-2002 10:41:39
 Re: Re: Need help with Super 55 in reply to RustyHulk, 01-20-2002 20:57:07
Thanks RustyHulk, I went out and tried your trick and that is the culprit.
