Requesting info. on 3-71 5-43 GM Engines
Green Giant
01-19-2002 17:01:52
Which of these two engines are the best and and which is less exp. to increase horsepower. Also is the 990, 1900 or 1950, which is the best durability ie. tran. & final drive. One other question what motor does the 2150 have. Thanks
Eric The Red
01-20-2002 16:41:19
 Re: Requesting info. on 3-71 5-43 GM Engines in reply to Green Giant, 01-19-2002 17:01:52
There was a retired Detroit Diesel mechanic on here this past summer (email [email protected])and in his opinion he liked to work with the 3-71. The 3-71 and 4-53 blocks are not the same. The 71 uses dry type cylinder liners while the 53 uses wet liners. 71 is larger cubic inch displacement.In my estimation the 71 has a lot more potential for a puller as it is built much heavier and stronger than the 53. Also more injector and blower options. This was his opinion to me on which engine to use and he would be willing to work with someone if they wanted to build one. If I ever can get money to buy one would love to do it.
1206SWMO
01-20-2002 15:54:43
There used to be a 12,000 lb Oliver 1950 SS pulling tractor here in Missouri in the early-mid 1970's.He had a turbo on the 4-53 Detroit along with the supercharger and had to be making close to 350-400 horses and turned at least 3500-4000 rpms.I'm guessing he ran high 4th.
He came down the track about as hard as the 400 horse IH's and AC's did.He ran 23.1 x34's or 24.5x32's.Getting 2 horses per cubic inch should be possible on a 4-53.
If I remember right his name was David Putnam and he was from Palmyra,Missouri.I have no idea if he is still around yet.
Some of your Detroit powered 20,000 lb pulling semis are sure making lots of horses like John Mann from Ohio.
m kuhns
01-19-2002 17:23:22
The 1900 or 1950 rear and trans are definetly stronger. I was told that the bull gears in the 1950 were stronger(wider) than the 1900's. The 99 rear is basically the same as an 88. The engine are just about equally priced to increase the power. The 4-53 you will have to buy one more injector than the 3-71. With a turbo 350-400Hp is not out of reach with either of these engines. The bottom end however on the 4-53 should have one more main compared to the 3-71.
John Mann
01-20-2002 07:35:52
 Re: Re: Requesting info. on 3-71 5-43 GM Engines in reply to m kuhns, 01-19-2002 17:23:22
I have a 990 and it has dynoed 115 hp also have a 1950 have run it yet but I am when I get a chance. I would think 200 hp on the 4-53 is reasonable, more so on the 4-53 T model. The 3-71 I have tends to run hot if I load it heavy. I don't know about 400 hp on one of those , I wouldn't want to be standing around one of them turning 400hp. Also seen alot of these little motors they are supprisingly powerful.
super99
01-19-2002 20:00:49
Obviously you have never seen the 88 and 99 side by side. The transmission in the 99 is quite a bit heavier to say the least.
Big Time
01-19-2002 20:43:55
 Re: Re: Re: Requesting info. on 3-71 5-43 GM Engines in reply to super99, 01-19-2002 20:00:49
And i want to see these 450 hp 4-53 detroits. must be on nitrous, water injecttion, turbo off a D9 dozer, and hooked to a 450 Cat.
mike
01-19-2002 21:10:23
 Re: Re: Re: Re: Requesting info. on 3-71 5-43 GM Engines in reply to Big Time, 01-19-2002 20:43:55
never seen one of the smaller ones on a dyno but on the bigger ones 2+ hp per cube is very obtainable to the tune of 3200 horse 16v92 wouldnt have believed it unless i had seen it .mike
Olddog
01-20-2002 03:55:37
 Re: Re: Re: Re: Re: Requesting info. on 3-71 5-43 GM Engines in reply to mike, 01-19-2002 21:10:23
Curious to know, Mike, what rpm were they turning these 2 cycles? Any major exhaust tuning?
mike
01-20-2002 10:57:57
 Re: Re: Re: Re: Re: Re: Requesting info. on 3-71 5-43 GM Engines in reply to Olddog, 01-20-2002 03:55:37
this motor was running 3200 rpm this was in 1992 i believe and it has gone through major improvements since. I believe it holds the world speed record for a diesel powered truck at bonniville known as the PHEONIX as far as exaust tunning I don't know if anything was done to the heads but i'm sure there had to be some cam work exaust pipes were 6"and about a foot long off each of the 4 turbo's .mike
JD790
01-19-2002 21:44:51
Are you sure that was a 92 and not a 149? I can't remember if the ferry boat motor I saw in Seattle was a 16 or a 12V-149 Detroit simply called it the 149.
mike
01-20-2002 10:47:19
 Re: Re: Re: Re: Re: Re: Requesting info. on 3-71 5-43 GM Engines in reply to JD790, 01-19-2002 21:44:51
yes it was a 92 series they do make a 149 and a 278 also but this was 16v92 running 3200 rpm and 4 big turbo's with about a foot of straight pipe sounded awsome mike
Nathan Gray
01-19-2002 17:08:27
The 2150 has a White-Hercules 478 ci. turbocharged diesel.
