Tractor tire chains?
jeff
01-19-2002 14:14:05
hoping someone with experience can answer a couple
questions.
I have a super 55 I use year round and have a set of double ring chains for it and
love them . never get stuck.
I now have two other tractors i would like to make snow and mud worthy. 1655 and a mm602 (18.4-34) & (15.5-38)
double rings are expensive . they sell two other types ( highway = straight chain links ) ( field = kinda x shaped pattern )
what are the 3 types each best at ??
if it didn't make a difference they wouldn't make three kinds right??
ct is going out of business and stuff is 60% off
thanx jeff
jdp
01-19-2002 19:40:42
 Re: tractor tire chains? in reply to jeff, 01-19-2002 14:14:05
I would rule out the highway chains right now. Now, between the field and double ring, it is a matter of preference. You will have good luck with either one of them in mud, snow, or ice. The field chains run a little smoother on the road than double ring. Double ring do clean good. The field chains will always be on top of the tread. It depends on what you like or "This is what my father uses". One of the tractor chain manufacturers said that the double ring chains are only popular in the northeastern states. If you do buy the field chains, you will be very satisfied. I use and sell both styles.
Jake
01-20-2002 21:31:27
 Re: Re: tractor tire chains? in reply to jdp, 01-19-2002 19:40:42
Try tirechains.com that their only business and they have all types of chains and give a price with out contacting the co. Tried and liked the svc.
