Oliver 550 steering
Bob Stites
01-12-2002 19:38:31
My steering turns so far that the tires rub against the power steering cylinders. My guess is a previous owner rotated the pitman arms too far behind center. With the wheels straight ahead, both arms are rear of vertical by about 15 degrees. The pitman arms look like they will be big trouble to get off (they're heavy, and there's no place for the puller to grab).
Any advice, experience to share?
Mike (WA)
01-13-2002 09:18:49
 Re: Oliver 550 steering in reply to Bob Stites, 01-12-2002 19:38:31
There should be "stops" on the steering box that will prevent the pitman arms from going too far. I'm at the office and can't go look at my 550 now, but if memory serves, the stops can be removed, so may be missing from some prior owner's rebuild.
Bob Stites
01-14-2002 18:47:06
 Re: Re: Oliver 550 steering in reply to Mike (WA), 01-13-2002 09:18:49
I think you're right on. The shop manual, under "Installation" (page 8-104), says: "Install the four pitman arm stop spacers, the stops (if so equipped), the four mounting cap screws and lock washers."
There is even a figure (8-204) with a label pointing to "stop with spacers on each side".
My manual is a xerox copy and the illustrations are terrible, so I can't make out what the stops look like or what they're attached to. I don't have any stops and the "if so equipped" phrase led me to believe I wasn't supposed to. Please describe the stops; maybe I can make them. Are they attached to the center frame cover?
Thanks, Bob Stites
Mike (WA)
01-15-2002 08:32:19
 Re: Re: Re: Oliver 550 steering in reply to Bob Stites, 01-14-2002 18:47:06
Will take a pic and email it to you- but will be a couple weeks, as I am gone this weekend and am never home during daylight during the week. Basically, the stops bolt to each side of the base of the steering gear, using the bolts that attach the steering gear to the center frame.
Bob Stites
01-15-2002 17:52:32
 Re: Re: Re: Re: Oliver 550 steering in reply to Mike (WA), 01-15-2002 08:32:19
Thanks for the offer, but you won't need to take a photo; I just found a picture in the parts manual page 8-7, item 21 of the exploded view. The stops appear to be quarter inch plates with a short, L-shaped ear at the forward end, bent down at a right angle. There is a spacer under each of the two bolt holes, apparently to lift the the plate up enough to clear the steering housing. Can you tell me:
1. Am I right on the plate thickness etc.?
2. How far behind the front bolt-hole is the edge which stops the pitman arm?
I very much appreciate the advice you have given.
Bob Stites
Larry from Maryland
01-13-2002 06:32:26
You may have to adjust the length of the tie rods.What size tires do you have on?
Bob Stites
01-14-2002 18:55:49
 Re: Re: Oliver 550 steering in reply to Larry from Maryland, 01-13-2002 06:32:26
That's the first thing I thought of, but it won't work. Stop to think about it. If you lengthen the tie rods to keep the tires away from the hydraulic cylinders, you throw the wheels out of allignment (toed out). Please read the response from Mike, and my reply. Thanks for your answer.
Pete
01-12-2002 20:26:51
Bob - The 15 degrees behind center (both r & l) is the corect position for the pitman arms when the wheels are stright ahead - these arms are indexed by a double spline and can not be put on in the wrong position - - you have other problems! check the steering wheel to see if it is in the center of its movement (same number of turns to right as to left)
Pete
Bob Stites
01-14-2002 19:00:53
 Re: Re: Oliver 550 steering in reply to Pete, 01-12-2002 20:26:51
I think you're right in saying I have other problems. Please read the reply from Mike, and my answer. Apparently a previous owner removed the pitman arm stops from my machine. Trouble is, I don't know what they look like or where they go. If you have a 550 and can tell me, I would much appreciate it. Thanks.
