Oliver 60 , Front Crank Seal
Jerry T.
01-07-2002 18:31:46
The engine is a 1942 that needs help with the front seal. Is there a remedy without replacing the seal? If replacing the seal is the best solution, does the timing gear cover have removed to replace the seal? If seal, where do I find a replacement?
Canada Grant
01-11-2002 10:10:01
 Re: Re: Oliver 60 , Front Crank Seal in reply to Joe, 01-07-2002 19:45:35
You have to remove timing gear cover to replace the seal. The original is a cork seal on a metal retainer. IF it has been running metal on metal there could be a groove in timing gear cover, a little metal epoxy will smooth it out for a better seal. You should check the oil pickup screen as the cork will end up there starving oil pump. Even if guage is showing good pressure I have seen some cruddy looking screens.
