Oliver 55 Clutch
Brian Harding
01-06-2002 21:34:51
Hello
I have an Oliver 55 that need a clutch. Any and all tips, tricks ec. will be appreciated. I am fairly good at mechanical stuff but havent split a tractor apart yet. Thanks in advance
Brian
Dale
01-15-2002 19:27:55
 Re: Oliver 55 Clutch in reply to Brian Harding, 01-06-2002 21:34:51
The clutch housing splits horizonily with the top
half staying with the dash & the bottom half
staying with the rearend. The stabilizers from the front axle have 3 bolts on each side of the clutch housing that come out. Have a floor jack under 1 end with other end blocked up. Caution When you reassemble be real easy with it Take your time & dont get to rough. Put a pipe wrench on the power take off shaft & gently turn to line the splines as you ease it together.
Super 55
01-06-2002 22:19:03
I had the instructions on Photopoint, but it's gone now. I will try to get them on Fotki as as possible. It is an easy split though.
