Oliver 60 cylinder sleeve
Ben Haag
01-04-2002 21:29:14
I recently bought a used sleeve for my oliver 60. It is the wet type sleeve and the o rings ar a little bit chipped at the bottom. should i replace them? of just smear grease all over them??
Ben Haag
01-05-2002 08:56:19
 Re: oliver 60 cylinder sleeve in reply to Ben Haag, 01-04-2002 21:29:14
where can i get those o rings?? i only need 2 of them.
Canada Grant
01-05-2002 09:24:52
 Re: Re: oliver 60 cylinder sleeve in reply to Ben Haag, 01-05-2002 08:56:19
Should be still available from White
Canada Grant
01-05-2002 06:13:27
Change the o rings a lot cheaper than a teardown when it starts leaking !!! Especilly after you have done a repaint on the tractor,I prefer to run my rebuilds for a while before I paint just to find leaks / problems you don,t know of. I know of two retorations that went sour after the final painting ,both bad ,one siezed engine,one dropped valve,both perfect restorations that didn,t look so nice after the re re build.
