Electronic ignition
Ron Frelich
02-19-1999 05:46:14
Where can you get an electronic ignition change over for a 1650 oliver gas tractor with a holley distributor. Having problems with burning points
Dean
03-04-1999 07:30:24
 Re: electronic ignition in reply to Ron Frelich, 02-19-1999 05:46:14
I solved the same problem on my 1650G by replacing the coil with a resistor coil. NAPA sells the correct one for this application.
jack
02-25-1999 12:24:21
put a resister on the coil
Von WC Ohio
02-19-1999 19:27:47
Try the following contact:
for electronic ignition for tractors,combines etc.
(must use neg. ground I believe)
Denny's Carb. & Ignition Shop
Fletcher, Ohio
Phone # (937)-368-2304
