Unknown year on Oliver Tractor
Nick Gray
02-18-1999 08:49:04
I want to know what year this tractor is that I have. I think that it is a Oliver super 88 industrial but it is hard to tell because it doesn't say on the serial no. plate. The serial number is 43-436-813 which is located under the dash. The decals are mostly worn off but the paint is fairly dull color yellow. The transmission is set up like a shuttle shift with a lever on the steering column for forward and reverse. The front tires are the same as what is on a semi and the rear tires are I think 16.9x34. The tractor also has a heavy duty loader on the front. If you know anything about this tractor that goes with my question please email. Thanks
Kerry
02-18-1999 19:50:18
 Re: Unknown year on Oliver Tractor in reply to Nick Gray, 02-18-1999 08:49:04
It appears to be a 1956. Not sure if it is a Industrial or not. Nebraska Test Data from 1954 is Diesel Observed Belt Hp 54.88
Gas Hp 55.77
6 cyl @ 265 cu. in. I hope this helps.
