Just picked up a '57 Oliver Super 55. We're going over the tractor and fixing the minor things we find wrong with it or are missing. I don't know a whole lot about this tractor since it's so different than Oliver's other tractors. I plan on getting a manual for it soon. I've got a few questions for Super 55 owners, hopefully they can help me out. Here they are:1. My throttle rod (the part going from the throttle shaft in the dash to the part that rotates) is not stock. Does anyone know what originally was there? 2. The throttle lever moves up when I try giving it more gas. There's something missing down below on the shaft that's not holding the lever from going up in the dash. It's got a spring with a washer, but all it does is give it spring pressure when pushing down on the lever. What holds the lever from coming up? 3. For the 3 point hitch, there's supposed to be stabilizer bars that you can put on for when you're working the tractor so the arms don't swing. Is there a bracket that bolts under the axle housing that those attach to? 4. Is the PTO shaft always supposed to turn a little even if it's not engaged? My lever (the longer style) has a lot of play in it on the shaft that mounts on the casting. It has about an inch of play between the cotter pin and the frame. Is there supposed to be a spacer in there or something? 5. Last question. Where the external hydraulic valve would mount, there's a hydraulic hose hooked on the housing and it makes a loop and goes back to the housing. Would anyone know what this is for? I don't think it is a hydraulic valve since there is no lever or anything. Thanks to anyone who replys and if anyone has any pictures to explain some of the parts that would be great. Jeff.
