Perkins 6-354 engine
Joe Hill
12-30-2001 20:15:54
I would like to know if the Perkins 6-354 Engine that was used in some Oliver Combines and also some Massy-Fergson Combines will interchange with the Perkins 6-354 Engine used in the Oliver 1850 tractor
Joe Hill
01-03-2002 06:43:43
 Re: Perkins 6-354 engine in reply to Joe Hill, 12-30-2001 20:15:54
Thanks guys for your info. Joe Hill
m kuhns
12-31-2001 12:03:59
They are same engine with a little heavier wrist pin and a beter cylinder head if it was turbocharged. The engine should fit if you change bell housings and the front timing cover. We put a bus engine in our one 1850 when a piston failed and put a hole through the dry sleeve. It was no shame for it because we were running over 160 hp out of it. There shouldn't be no reason it shouldn't fit if you just cahnge these two items, and possibly the exhaust and intake manifolds.
m kuhns
12-31-2001 12:02:20
m kuhns
12-31-2001 12:02:04
Larry
12-31-2001 09:13:40
I can tell you the gasket set will NOT interchange.The clutch houseing adapter is differant allso.The only good thing is perkins claims to have those new.
