Perkins
Jethro
12-30-2001 15:35:48
Can anyone give me some advice on how to bleed a perkins easy? i just got mine rebuilt and have been having a heck of a time getting the sucker blead out.
m kuhns
12-31-2001 12:17:48
 Re: Perkins in reply to Jethro, 12-30-2001 15:35:48
Open the air bleed plug by the timing window on the side of the injection pump. Leave in just far enough so only a little fuel could spill out with air. The injection pump needs to be completely filled up with fuel. Pump your hand primer on the transfer pump and fuel should fly about five feet when all the air is out of the system. Tighten up the plug and crack the high pressure lines. Crank the engine over until fuel starts sqirting out and retighten them. It should start just about right away - at the most 15 seconds after tightening the lines. If you replaced your nozzles the pressure required to open them might be too high indicating a weak injection pump. If you never get a steady stream of fuel coming out of your high pressure line when loose you have other problems. You could also have a leak on the suction side of your transfer pump which could be sucking air.
Larry
12-31-2001 09:10:19
If all the lines are dry first bled the system including the pump useing the fuel pump primer.Then pull the tractor with another to fire it up.It is much easyer on the starter and battery.You can allso get oil preasure up before it fires this way.
Delbert
12-30-2001 19:25:34
I assume you are bleeding the high pressure fuel lines. On all I have had problems of air in the lines I loosened the nut at the nozzles and cranked the engine till fuel came out all the lines. To bleed the low pressure lines find a bleed screw usualy at the top of the filters, open the screw and pump primer pump till no air comes out,close screw and see if there is a bleed screw near where the line enters the high pressure pump,do the same thing. The low pressure lines should be bled first. I have done this on Herculese,Waukesha and Catapiller, I have not done a Perkins it should be the same. Hope this helps. Delbert
