Cam for 88
John
12-29-2001 12:10:55
I have a 88 gas which I recently rebuilt the engine. It has super 88 sleeves and pistons and a super 88 head. Everything else is stock. I plan on pulling in a stock class. Is it better to have my cam reground or use one from a later model oliver? What oliver cam will fit? How does this effect the RPM on a stock puller as I can not go over the stock RPM by much? I am not planning on changing the carb or manifolds. Any help is appreciated.
m kuhns
12-30-2001 16:02:26
 Re: Cam for 88 in reply to John, 12-29-2001 12:10:55
Get a Gingrich cam if possible. They offer great low end power and torque when degree'd in properly. I think a machine shop in Harrisburg, Pa. named Feesers has a grind for this cam and should only cost about $100 to get your cam reground to this grind.
RCP
12-31-2001 05:16:54
 Re: Re: Cam for 88 in reply to m kuhns, 12-30-2001 16:02:26
Can you provide more info on Fessers, I have not been able to find a phone listing for them.
m kuhns
12-31-2001 10:56:55
 Re: Re: Re: Cam for 88 in reply to RCP, 12-31-2001 05:16:54
I mispelled it wrong. I is Feeser's with two e's. I don't know much about them, but a fellow puller told me about them. He gets all of his machine work done there. I want to get another cam ground also. I might have to make a few phone calls if this is not the correct spelling.
