Starting and Oliver after being idle for 3 years
Mark
12-26-2001 09:44:42
Well, I am on the home stretch. After 3 years and many transmission gears and bearings later, I am final ready to reassemble my tractor. My question is is there a need to prelube the engine before trying to start the tractor. I have not done anything to the engine as it ran fine before.
Bob M
12-26-2001 17:46:03
 Re: Starting and Oliver after being idle for 3 years in reply to Mark, 12-26-2001 09:44:42
We had an 1850 (gas) that sat in the shed for 4+ years. When we went to restart it, here's what we did:
1 - Removed all the spark plugs and shot a couple squirts from the oil can into each jug.
2 - Checked to make sure the crankcase was full.
3 - With the plugs still out, cranked the motor until about 20 psi showed on the oil pres gage. (Recommend you keep clear of the plug holes while cranking!)
4 - Screwed the plugs back in, checked to make sure the governor to carb linkage was free, then cranked 'er up.
We were rewarded with a brief but satisfying cloud of blue smoke followed by a smooth running motor. Apparently the long layoff caused the motor no permanent harm.
