Oliver 70 clutch rod won't move
Philip Covalesk
12-22-2001 14:42:35
I've got an Oliver 70 and it's clutch rod won't move. The pedal moves but the rod starts to bend. Does anybody have any suggestions on how to fix this one? What could be stuck?
Thanks!
Canada Grant
12-24-2001 19:42:25
 Re: Oliver 70 clutch rod won't move in reply to Philip Covalesky, 12-22-2001 14:42:35
There is a tin plate on top of the bell housing remove it and see if its stuck inside there on shaft you may be able to move it with pry bar gently ! or clutch stuck to pressure plate or flywheel.
