8 volt 88 ?????
Tim K
12-21-2001 17:12:43
What would it take to convert an 8 volt 88 to 12 volt?
Andrew in New Brunswick
01-08-2002 20:46:50
 Re: 8 volt 88 ????? in reply to Tim K, 12-21-2001 17:12:43
Tim....8 volt batteries are available.Check at www.antiqueautobattery.com They got everything in batteries.There located in Ohio.Hope this helps.
Canada Grant
12-22-2001 11:46:59
I.ve ran 12 volt and 8 volt on 88 standards and can see no differance in starting so are you sure everything is working good in 8 volt system . Such as starter, cables etc . Actually just put 6 volt generator back on ,as it has movable third brush turned up volts and drove on .
Delbert
12-22-2001 08:29:59
With 12v your old light bulbs will likely blow before you get your hand loose from the switch, I would put 12v bulbs in, although the coil will probably work for a while I would put a good resistor on the old coil or the best solution would be a 12v coil. When I bought my 88 it had been changed to 12v, whoever did the work messed up,changed battery to neg ground,put the resistor on the distributor instead of ahead of the coil. After putting up with poor starting and not running like an oliver should I put on 12v coil changed the polairity to pos ground, checked to be sure the coil was connected correctly. I could not believe the difference.
GEMALO
12-21-2001 20:02:57
12v battery & adjust reg. to put out 13 to 14 volts.
