Thanks Shep!!!!!!!!!! Also....
Tim Imrick
12-17-2001 13:20:30
'preciate the "They Said" article!
Can anyone tell me how many 2655s were produced??
-Tim
JK
12-18-2001 14:24:47
 Re: Thanks Shep!!!!!!!!!! Also.... in reply to Tim Imrick, 12-17-2001 13:20:30
Below is a listong of the serial numbers from a White/M-M dealer bulletin:
43900001- A4T 1400 1969 43900103- A4T 1400 1970
45700001- A4T 1600 (LP) 1969 45700126- A4T 1600 (LP) 1970 45700197- A4T 1600 (LP) 1971
45600001- A4T 1600 (DSL) 1969 45600188- A4T 1600 (DSL) 1970 45600701- A4T 1600 (DSL) 1971
From what I understand the 2455(A4T1400), 2655(A4T-1600) and Plainsman were just painted differently & in the same serial number range.
I have an original A4T sales brochure dated 1/72 that shows only the 504 LP & 585 Diesel engines being offered. I know some 800 LP engines found their way in some of them & have the supplement for the A4T manual for that variation but I never knew of any Cats being offered in them.
This same list shows the M-M G1355 (Oliver 2270)being made thru 1974.
John
Wrenchbender
12-18-2001 20:19:01
 Re: Re: Thanks Shep!!!!!!!!!! Also.... in reply to JK, 12-18-2001 14:24:47
Your serial number breakdown looks correct acordin to the books I have also. One book does give ending numbers so it looks like: A4T 1400-diesel, 247 units. A4T 1600 diesel, 1190 units. A4T 1600 LP gas, 257 units. The 2655 shows being available as a diesel turbocharged or NA. My "Progress in Tractor Power" book shows 2655, A4T, and White Plainsman all together. My books have pictures of the 2655 that has Oliver green paint scheme and a cab like a 4-150. The picture of the 2455 has no cab and has a different scheme, looks like a M-M. The other pic of the Plainsman also has the 4-150 cab. The only two I have ever worked on were a 2655 painted green, can't remember what the cab was like, and an A4T that was red and white. I don't think it had a 4-150 cab on it but it did have a cab. I think they built such a small number that each one could be a little different. WB.
D13 - Some numbers
12-18-2001 06:23:12
2455 or 2655?
Very similar, but the 2455 / A4T-1600 used the 504M-M and the At4-1800 used the 585M-M / Cat 575 (3140?) for Diesel, and the 504M-M for LP.
Judging by the starting serial numbers (I don't have the finishing numbers)(M-M and Oliver shared serial numbers):
For the 2455, they made them 2 years 69-70, and made 102 the first year. It leads one to suspect less than 200 were ever produced.
For the 2655, the LP and diesel were numbered seperately, they were made from 70-72. In the LPG, 70-71 they produced under 200, so the total was probably less than 300. For the diesel, they made 187 the first year. 1972 started with serial 701, so I can't tell if they got lucky and made 700 the first 2 years, or decided to increment to 701. Either way, one would suspect that less than 1500 were made, probably closer to 1000 (if I remember the financials in 72, it would be tough to buy one).
As far as the White Plainsman, I've not been able to find a listing on it. Were they built after the others? I can't find a White 4wd until the 4-150 in 74, so I would suspect that they repainted their leftover 72's for 73. If so, then the numbers produced for the 2655/ A4T 1800 / Plainsman would probably be close to above.
BRIAN
12-18-2001 12:13:31
 Re: Re: Thanks Shep!!!!!!!!!! Also.... in reply to D13 - Some numbers, 12-18-2001 06:23:12
I DIDN'T SEE IT,BUT A FRIEND SAYS HE DROVE A 4-150 FOR ANOTHER FARMER THAT HAD GREEN PAINT UNDERNEATH SILVER AND BLACK OF WHITE.
Shep
12-18-2001 05:15:57
No problem, I kinda like that article too.
I really cant tell how many of those tractors were built by my book because it is listed as three tractors, the 2655 Oliver, the AT4-1600 Moline, and the White Plainsman, so I really dont know how many of what were made. Maybe someone else can tell us.
