Which would be better to restore an 88 RC or a 77 RC?
Tim K
12-17-2001 09:45:18
I'm trying to decide which I'll overhaul. I need to overhaul a tractor for a class next semester. I have 88 Rowcrop gas with duals on the left side, I'm told this helped while plowing, and a 77 Rowcrop gas. I think one of them is a Super but I'm not sure how to decode the serial number to tell. THe 77 Rowcrop has been rolled. Its original steering wheel was replaced, yet it is still difficult to steer. The 88 Rowcrop has been sitting for close to 10 years now. The 88's engine was overhauled about 20 years ago. The 88 also might have a cracked block. The 88's tires are all dry rotted. Which should I overhaul?
Larry from Maryland
12-17-2001 15:03:24
 Re: Which would be better to restore an 88 RC or a 77 RC? in reply to Tim K, 12-17-2001 09:45:18
If you have both I would vote for the 77.Its lighter and easier to move,the tires are smaller and cheaper,You can switch the steering parts and avoid the expencive engine repairs.Look for flat places with bolt holes in the frame to tell if its a super.
Big Time
12-17-2001 13:17:16
never overhaul a cracked block. if you want to repair damage on one with a crack, go ahead, but if your sinking major overhaul dollars go get a clean block and head to start with. then your engine will last a lifetime. the idea of which one is up to you or maybe someone else will know more, but the engine i do know about.
