550 temperature sender
rwh
12-16-2001 17:06:28
I replaced the gauge cluster on my '59 gas 550 and when I fire it up, the temperature needle quickly goes to hot and stays there. I figured it was a clogged radiator hose or bad thermostat, but no problem there. I see no indication of a water pump problem. Is there any easy method for testing the sender? The tractor never gave sign of running hot before.
Frank
12-16-2001 21:11:45
 Re: 550 temperature sender in reply to rwh, 12-16-2001 17:06:28
Are you running the electrical system on 12 volt positive ground? The wrong polarity will ruin the gauges in the cluster.
rwh
12-17-2001 13:50:52
 Re: Re: 550 temperature sender in reply to Frank, 12-16-2001 21:11:45
Yep, 12V positive, with a positive ground gauge cluster straight from Korves Oliver. Wonder if maybe someone stuck an aftermarket negative ground sender in there and it's reading backwards?
