Serial number ID
Longtime GB FAN
12-16-2001 12:22:00
Can you tell an Oliver model number from a serial number alone? (13978-518) spec # 5-0005
Packer Backer
12-16-2001 18:55:40
 Re: Serial number ID in reply to Longtime GB FAN!, 12-16-2001 12:22:00
The tractor has a wide front. The shifting pattern is displayed on a plate mounted on the dash. It looks like it has 6 speeds and reverse. It has a lever, about 14 inches long, mounted on the right side of the transmission housing that only moves forward and back. The shift lever is on the left side of the housing. It has two oil fill/check holes on the top of the tranny housing under the steering wheel. The power take-off turns all the time.
Oli and Lena
12-16-2001 20:49:37
 Re: Re: Serial number ID in reply to Packer Backer, 12-16-2001 18:55:40
Am told you may have a '55 super 55. Start with that. Good Luck
John P.
12-16-2001 13:58:14
1955 Oliver Super 55.
