2255 Compression Spec?
Tim
12-15-2001 16:30:47
I have a 2255 with a dead cylinder.2nd cylinder back on the left side of the engine.If you start the tractor cold. The exhaust manifold port does not heat up on that cylinder as quick as the other seven do and it blows a grayish smoke like unburnt fuel or oil. It is also getting quite a bit of diesel in the motor oil.I have checked compression and it seems to have 250lbs on that cylinder would that be sufficient for a 3150 Cat? I was thinking it had a hole in the piston and putting diesel into the crankcase.None of my manuals list a compression spec.Any thoughts?
Tim
12-17-2001 19:25:07
 Re: 2255 Compression Spec? in reply to Tim, 12-15-2001 16:30:47
Pop tested injector nozzle.Injector was stuck open. causing problem.250lbs must be enough.
