Shep, What paint do you use
Craig A Tull
12-14-2001 18:48:34
Shep what brand and codes are you using on your 18XX series tractors
Craig
Shep
12-15-2001 13:57:06
 Re: Shep, What paint do you use in reply to Craig A Tull, 12-14-2001 18:48:34
Craig,
I have always used genuine Agco paint from the Agco dealer. It is about the same price as what I can get it from a good paint store here in town and I know it is the correct color.
I have tried using some BPS or cheeper paints from TSC and Farm and Family but that is mostly colored water and does not hold up. I sand the tractor down good with my air sander and use an etchless primer that I dont have to sand (Mostly because Im too lazy to sand a farm tractor twice) if I apply the paint within 30 minutes of applying the primer. So far it has worked well, I havent had any problems with the finish, but both tractors are less than a year on their paint jobs, so we will see.
D13
12-16-2001 05:32:40
 Re: Re: Shep, What paint do you use in reply to Shep, 12-15-2001 13:57:06
So you clean it up, scuff it, shoot the primer, then the color?
You said that the primer didn't need to be sanded if the color was shot within 1/2 hour. Are you painting sections then?
Have you tried the self etching primers without sanding the old paint? Allegedly you don't need to sand before applying them. I personally like to get the rust and old paint off, but several of the local resellers around here use this technique to get pretty decent results.
Always interested in what works.
Shep
12-16-2001 09:45:23
 Re: Re: Re: Shep, What paint do you use in reply to D13, 12-16-2001 05:32:40
Yeah that is the process I use. I generally take the tractor apart and the engine out, then pressure wash everything real good, sometimes twice, and sand the rust and old paint off, or what the air sander can get to, and shoot the primer. If there is a place that the primer doesnt look good I can resand if need be and put more primer on.
I hit the rear rims with primer and paint first and that is generally the only big area of white on the main part of the tractor. Then I can mask the rear rims and primer the frame and rest of the tractor, and you have to keep movin to get the green on in the 30 minute window, but you can get it done. Then I let it dry and put on another coat of green to make it shine.
The sheet metal I do in groups of green and white and just primer it and paint what I can do in about an hour at a time and I put on two coats.
There are always places the sander cannot get and sand, but the primer and paint stays pretty good so far. Like I said it works pretty good for a farm tractor. Parade tractors it would be a little different but I try to keep my paint jobs under $1,000 because the tree limbs and brush are going to scratch them up along, and I will have to repaint them as we use them. My Olivers have to earn their keep :-)
Craig A Tull
12-15-2001 18:54:09
How much, on an average does it take to paint a tractor " Oliver green" I'm sure a quart is enough clover white.
Thanks
Craig
Craig A Tull
12-15-2001 14:18:37
Do you start with all the sheet metal off, paint everything ,then assemble the tractor, it seems like there would be allot of unpainted bolts etc. Do you go back and give it one "top" coat after it's put together??
Thanks
Craig
Shep
12-16-2001 09:34:18
 Re: Re: Re: Shep, What paint do you use in reply to Craig A Tull, 12-15-2001 14:18:37
Yeah, I take all the sheet metal off, I usally have the engine out for another reason when I paint one so I can paint the engine haning off the forklift, and then I paint all the sheet metal on the ground or hanging in parts. I try to put all the bolts back in the frame or the tractor where they came out of when I disassemble anything. Its just a habit I have when working on anything, and it keeps the paint out of the bolt holes and gets the bolt painted too. You would be suprised, there are very few bolts that dont get painted. I have never gone back over afterwards with a topcoat when its assembled but you could. I am always afraid of getting green drift on the white if I went back over it. I just use a spray bomb to take care of anything little that I scratch when putting it back togeater.
I am trying to remember but I think it took two quarts of white and about a gallon and a half of green to do the 1850. Those big white rear rims eat up a lot of white.
Criag A Tull
12-16-2001 11:50:33
 Re: Re: Re: Re: Shep, What paint do you use in reply to Shep, 12-16-2001 09:34:18
Thanks Shep, your machines look great, I could only hope mine come out as nice.
