Wrenchbender ! Do you still have your Oliver 4340 plow?
ShepFL
12-14-2001 18:43:03
While digging thru the archives I seen a post from '99 that you had one of these with hyd. lift. Do you still have it? I'm seeking some information on setup and the like. I have one sitting in SC waiting for me to pickup. So far I have been unsuccessful locating any literature (EBAY, AGCO etc). Any leads in the right direction should would be appreciated.
Thanks,
ShepFL
ShepFL (Thnx WB CG) CG - your email broke?
12-19-2001 12:42:31
 Re: Wrenchbender ! Do you still have your Oliver 4340 plow? in reply to ShepFL, 12-14-2001 18:43:03
WB - Thanks for the assistance. Looking fwd. to the information (if avail) from the microfisch. Still need your email to send pic
CG - whenever I send email to you it bounces back as recipient not valid. Try to drop me a line and I will reply with pic.
Wrenchbender
12-15-2001 13:04:27
Yes I have a 4340 plow. It is a 3 bottom pull type with hyd lift. What info do you need, I will try and help if I can. WB.
ShepFL
12-15-2001 14:47:35
 Re: Re: Wrenchbender ! Do you still have your Oliver 4340 plow? in reply to Wrenchbender, 12-15-2001 13:04:27
OK WB -
1st - Thanks for the rapid reply.
2nd - Happy Holidays
Now then -
I am seeking any information on this plow you may have. I bought one from a fella in SC. Still have to pick it up. Probably early Jan.
Particulars -
a) will be pulling it behind 550 Dsl in sandy FL soil - comments requested on proper setup.
b) Were they always mechanical lift?
c) If mechanical and welded in place are spare parts avail?
d) Do you know of a good source for parts?
e) On the hyd lift can are there any aftermarket parts?
f) Were they mech lift converted to hyd?
g) If hyd, when did Oliver make them?
h) Read that they had either trip bottoms or trip beams. Hard to tell from pics I have but would suspect trip bottoms, if anything. Yours? i) How hard are points, moldboards, shins etc to come by?
That's all for now. If you provide email I can send pics of mine. Would appreciate any pics you may have for reference.
Thanks.
Wrenchbender
12-16-2001 18:00:49
 Re: Re: Re: Wrenchbender ! Do you still have your Oliver 4340 plow? in reply to ShepFL, 12-15-2001 14:47:35
I'll do my best but I'm no plow expert. These plows could be set up as 14" or 16". They bolt together and when you look at yours you'll see how to change the spacing. The 4340 is a newer model of the same plow design. The older ones were numbered 214b, 316a, 414a, ect. These older ones my have been trip or hyd lift either. All the 4340s I have seen are hyd lift. The moldboards, shears, landsides, and shins are all replacable and should be available. The trip is probally either a shear bolt or manual reset. I have a friend who has parts fiche for Oliver impelments, I'll check them to see about the manual lift vs. hyd and get back to you. WB.
Canada Grant
12-17-2001 11:00:26
 Re: Re: Re: Re: Wrenchbender ! Do you still have your Oliver 4340 plow? in reply to Wrenchbender, 12-16-2001 18:00:49
I,m still using 4340 plows here !! Most are 14" here although I have a 12" 3 furrow. Three should be ok for 550 if you have traction although 16" could be a pull. Bottoms are manual reset no shear bolt and TSC has parts for the bottoms. I have found White shears are better in stones as they don,t bend like TSC ones but you get what you pay for! Most are hydrolic but the parts book does list the manual lift but I,ve never seen any. The depth wheel adjustment on furrow side can give trouble from breakage /missuse the lever can break off but but do adjustments with plow on ground as there is less stress, and if you have never plowed ask!! I,ve seen some wonderfull mess,s made!
