Flywheel and Clutch
Rich
12-13-2001 13:18:23
Will an Oliver 1600 flywheel bolt to a Super 77 crank, and everything still work (driveshaft, power takeoff, throwout bearing etc). The reason I ask, is I have a 1600 flywheel pressure plate etc, and I would like to install them in the S77 to get the 12" clutch.
Thanks
Rich
HAMHOCKS
12-14-2001 09:58:09
 Re: Flywheel and Clutch in reply to Rich, 12-13-2001 13:18:23
IF IT WAS A CRANK FROM AN 88 YOU COULD DO IT I DONT THINK YOU CAN WITH A 77 CHECK WITH AN AGCO WHITE DEALER HE CAN LOOK IT UP ON PARTS COMPUTER TO CHECK PART NUMBERS THAT WILL TELL YOU FOR SURE
Larry from Maryland
12-13-2001 14:06:42
I know the S77 and 1550 are the same,except some people claim the ring gear is differant.When the new selonid starters came out guy's wanted to put them on the older tractors.The dealers claimed it would work if you changed the starter ring gear.I would think lineing up the starter on a larger diameter flywheel would be hard.
