Cockshutt 540
FLYWHEEL QUESTIONS ...
Alberta Mike
12-11-2001 19:21:45
I have a friend of mine who needs to locate a flywheel for a Cockshutt 540 that has the little Continental flathead engine (gas). So far he has totally struck out after contacting a number of wrecking yards. Does anyone out there know if that flywheel was a one-of-a-kind flywheel or did it show up on other Cockshutt models, perhaps earlier ones like the Cockshutt 30 maybe? The flywheel is about 14 1/4" in diameter and it has 112 teeth. He was told that there were two sizes of flywheels for the 540 and this was the large version (with a smaller starter). Any advice or leads you could supply would be appreciated. He is the supervisor of a youth camp and with the snow we've had, he's getting desperate.
Denis
10-17-2004 08:31:58
 Re: Cockshutt 540 - FLYWHEEL QUESTIONS ... in reply to Alberta Mike, 12-11-2001 19:21:45
If you are parting out a 540 I would be interested in the crown and pinion gears. My son has a 550 and as far as I have been able to find out those two gears are the same. We put new bearings and one gear in this one but would like to have a few spare parts.
Gary
12-12-2001 07:41:01
I have a 540 I was thinking about parting out tell
him to give me an email
Denis
12-02-2005 07:55:57
 Re: Re: Cockshutt 540 - FLYWHEEL QUESTIONS ... in reply to Gary, 12-12-2001 07:41:01
If you are parting out your 540 I"d be intersted in the crown and pinion for spares.
Craig Embree
10-05-2004 20:25:59
Hi Gary: I also am looking for a part for my Cockshutt 540, and would be interested if you have parted out yours. I need the coupler and the 16 tooth gear that connects to the hydraulic pump on the right front side of the engine. Please let me know if you can help. Craig
David
07-04-2004 19:48:49
if you part out the 540 let me know, looking for a intake/exhust manifold
dvd
08-07-2006 19:12:06
 Re: Re: Re: Cockshutt 540 - FLYWHEEL QUESTIONS ... in reply to David, 07-04-2004 19:48:49
Re Manifold, if you have a fork lift dealer in your area some of them use the continental engine I got a manifeold from one and only had to modify the carb connection works fine The continental engine I got it from had been changed to propane works fine
Neil
