White 2-105 hydrolic HELP
Larry from Mary
12-07-2001 15:10:32
I finally removed the duals to replace a tire and fix the hydrolic.I put the outside dual back on,so I could run it and still have good axcess.Its still overheating and overheating the engine too with the oil cooler in front of the raditor.By holding my hands on the parts the heat starts in the pump and goes to the steering and the main preasure hose to the remote outlets.Apparently the mutiple valve is not leaking the return line does not get hot rightaway.So I removed the remote valves but can't find anything wrong.Preasure relief valve is working at 2450 psi and pump preasure can be varied from 1500 to 2450.Is there a way to test thease remote valves? Anyone have an idea what to try next.
don
12-07-2001 20:30:23
 Re: White 2-105 hydrolic HELP in reply to Larry from Maryland, 12-07-2001 15:10:32
dose hydrolic make noise? try moving three point hitch lever down a small amout.if that helps lever needs to be ajusted.
Larry
12-08-2001 08:44:55
 Re: Re: White 2-105 hydrolic HELP in reply to don, 12-07-2001 20:30:23
It does the same with the 3 point in any place evan down all they way.
Lee
12-07-2001 20:28:40
Have you done a leakage test on the pump?
Larry
12-08-2001 08:50:25
 Re: Re: White 2-105 hydrolic HELP in reply to Lee , 12-07-2001 20:28:40
No but the pump is a new rebuilt one.My IT manuel has maney of the tests left out includeing that one.
