1650 cockshot
bruce
03-01-1998 17:44:06
I am looking for a manual or information on repairs to the hydro drive. I have a leak from behind the flywheel. Someone said it was a hose or pipe that was the problem. Anyone know what and how to get to this pipe?
curt
03-10-1998 19:53:06
 Re: 1650 cockshot in reply to bruce, 03-01-1998 17:44:06
The Cockshutt 1650 is the same as the Oliver 1650 and I & T publishes a service manual. The can be aquired from Farm and Country or Tractor Supply Company.
My 1650 Oliver had a leak on the right side by the filter and the leak was from a deteriated hose. I replaced it with a brake line from an Auto repair shop.
Good Luck
: I am looking for a manual or information on repairs to the hydro drive. I have a leak from behind the flywheel. Someone said it was a hose or pipe that was the problem. Anyone know what and how to get to this pipe?
Larry H.
03-02-1998 17:17:28
I beilieve the hose you refer to is the small hose on the outside of the hydro unit, this hose leaks because of an "O" ring failure on the inside of the unit. IF this is the problem, the unit has to be removed from the tractor and repaired. There is also a seal on the main shaft that sometimes causes a leak from under the tractor. When the seal fails, it is usually a major leak. If you need more info, e-mail, because we repair Oliver tractors.
