Need a Rebuild Kit for a Oliver 6 cyll model 770 Diesel
Dan Cheney
02-14-1999 10:20:53
If anyone has or knows where could find a rebuild kit for a Oliver model 770 6 cyl. diesel please email. I am also looking for just the rod & main bearings and a set of rings as well.
jeff
02-15-1999 14:27:29
 Re: Need a Rebuild Kit for a Oliver 6 cyll model 770 Diesel in reply to Dan Cheney, 02-14-1999 10:20:53
sorry wrong subject
jeff
jeff rzepka
02-15-1999 14:25:38
any chance it's a postive ground system and its
hooked up backwards.
my 1953 oc-6 (oliver77)is positve ground if i'm
remembering correct
good luck
Jason
02-15-1999 15:09:12
 Re: Re: Need a Rebuild Kit for a Oliver 6 cyll model 770 Diesel in reply to jeff rzepka, 02-15-1999 14:25:38
You're right! We have an 880 that we switched from the convential starting to the more advanced starting. We had to switch our grounding.
Jason
02-14-1999 14:32:22
Talk to O'Brien County Implement. They are located in Sheldon, Iowa. They are big in Oliver stuff.
Kevin Coers
02-14-1999 19:15:27
 Re: Re: Need a Rebuild Kit for a Oliver 6 cyll model 770 Diesel in reply to Jason, 02-14-1999 14:32:22
You might give Maibach tractor a call, they're located in Creston , OH 800-808-9934.
C. Ziegler
02-20-1999 09:33:25
 Re: Re: Re: Need a Rebuild Kit for a Oliver 6 cyll model 770 Diesel in reply to Kevin Coers, 02-14-1999 19:15:27
Try any TISCO dealer as well. They will probably be cheaper than AGCO and you can over bore to 3.75" I think and get some real snort. Crankshaft seals will have to be purchased through AGCO-$100.
