Oliver 1850 Gas Vs. Diesel ?
Dale Frenz
12-03-2001 19:44:27
I'm looking at buying an 1850 Gas tractor. Anybody have any advice or experience with these? Any pros or cons I should watch for? Was it the Gas and/or the Diesel that was known for blowing rods?
Any help would be greatly appreciated. I'm planning on doing something about buying the tractor this weekend.
Direct E-mails are welcome.
Big Jim
12-05-2001 14:10:45
 Re: Oliver 1850 Gas Vs. Diesel ? in reply to Dale Frenz, 12-03-2001 19:44:27
Personally, I would always opt. for a diesel engine over a gas engine in a tractor of that size. A good 1850 Diesel with the Perkins motor will last for years and years if you take care of it. If you get an 1850 gas you will need to invest in a larger fuel barrel. Just my 2 cents worth.
JDP
12-04-2001 14:35:46
I would stay away from the Waukesha engine. I have heard very few positives on that engine. Besides the make of the motor, the gas wouldn't be as efficient as the diesel. I never cared for Perkins engines myself, but the three I have in my 1850's are good running engines. The 354 Perkins seems to be tough, and the parts are available from other sources besides the dealer. The only thing we ever put on the engine was a valve cover gasket. I have heard a lot of people say that the 1850 with the Perkins engine was the best Oliver made.
Shep
12-04-2001 16:57:31
 Re: Re: Oliver 1850 Gas Vs. Diesel ? in reply to JDP, 12-04-2001 14:35:46
I dont think that the Waukesha gas engines ever caused much of a problem, it was the diesels that were the pain, specifically the 310ci waukesha. I will totally agree with you that the 1850 Perkins diesel was one of the best olivers to roll out of the plant, and if you can find one that is the way to fly.... Just my 2 cents for today..... ..
doug vose
12-04-2001 17:11:48
 Re: Re: Re: Oliver 1850 Gas Vs. Diesel ? in reply to Shep, 12-04-2001 16:57:31
You got it, the 1850 with the Perkins were the best damn olivers in my mind. i used to work on a farm that only used olivers, with the exception of two White 2-135's, and an IH 1486. We had 1 770 gas, 3 1650 diesels, 1 1550 gas, 1 1550 diesel, 1 1755 diesel one 1800 diesel (my favorite), 1 1855 diesel, 1 1955 diesel (had a jd engine in it), 6 1850 diesels, and 1 1850 gas. had a few parts tractors too. One of em was an 1850 with a rod blown out the side. we took one 1850 and put a perkins engine in it that was dyno'ed at aroun 145/150hp!! It had big fat duels on it, and it would still spin the tires if ya let the clutch out too fast! We had that thang weighted, too.
Just thought i'd share my oliver experience with ya :)
Bob M
12-04-2001 07:31:55
We've had an 1850 gas for 35 years and 8,000+ hours. It's been an very reliable and trouble free tractor. The Waukesha-built engine has proven to be extremely tough - unlike the chronically rod-throwing and crank breaking motor in our ill-fated 1750 gas. The only major drawback is the 1850 gets thirsty when working hard - can easily burn 6 - 7 gallons/hour pulling 6-16's. Also for heavy tillage we found the front end is rather light. Adding 500# in front helps keep the wheels on the ground.
Problems have been minor - mostly normal wear items like belts, hoses, brake disks, and the like. The Marvel-Schebler carburetor tends to run lean as it ages - causing the motor to stumble when the throttle is suddenly opened. Solution is to rebuild the carb, being sure to replace the accelerator pump diaphragm when you do. After a carb rebuild the motor again runs like new.
If the price is right I'd go for it!
