Help with 77 oliver, It bogs down when under load
dave westlund
12-03-2001 19:01:45
Seems like it bogs down. If I'm running the tractor and give it gas quick it sputters or quits. It seems like it started to do this all of a sudden, but can't remember for sure. Also seems to start harder than normal.
Any suggestions on where to start?
Thanks Dave
Dick L
12-05-2001 17:12:22
 Re: Help with 77 oliver, It bogs down when under load in reply to dave westlund, 12-03-2001 19:01:45
If you have checked all the good tips given below and you still have a problem, you might check the mechanical advance weights in the distributor.
I had one that ran like a top at idle untill it was put under load and then wouldn't pull your hat off. I don't even want to admit how many times I had the carb, gas lines, sediment bowl, off. Two new sets of plugs and new points and condencer. I still don't know why I took the distributor off and stripped it apart and checked under the plate, but I did and I found my problem. Na, it couldn't happen to any one else, I own that kind of luck.
Jerry B
12-04-2001 06:06:28
I would start with adjustment of the main jet in the carb. If it helped I would then overhaul the carb. Kits only cost about $16-$18.
Plugs and plug wires would be second thing to check. Also the points and condenser.
Those four things should take care of it. Of course you may have a problem with the govenor.
jethro
12-04-2001 05:12:55
Check plugs wires and cap and rotor,and points
Lee
12-03-2001 20:28:53
I would check the main load jet, you may have some dirt or rust in it. Have you tried opening the main load jet up to see if it helps?
Lee
12-03-2001 20:28:18
don
12-03-2001 19:30:44
check to see if you have water in the sedament bowl. second thing would be replace the condencer
dave westlund
12-03-2001 19:38:45
 Re: Re: Help with 77 oliver, It bogs down when under load in reply to don, 12-03-2001 19:30:44
I did clean out the sediment bowl, but did not replace the condenser. What would the condenser do that would cause this?
Thanks fore your help! Dave
Hugh MacKay
12-09-2001 02:37:17
 Re: Re: Re: Help with 77 oliver, It bogs down when under load in reply to dave westlund, 12-03-2001 19:38:45
Just an old IH guy evesdroping, just went through the same thing with a Farmall. In 1956 I encouraged my father to take a look at an Oliver Super 77. We did and he bought a 300 Farmall. By the time I was doing the buying Oliver as we know it was gone from Canada, anyway. Not many Olivers around Nova Scotia. I know where there are a couple parked in sheds. I never really got those Super series Olivers out of my system. I may have to buy one of those shedded tractors and restore it. Just want to listen in on you guys first and get educated. One problem, super series guys are awfully quiet.
