Need some advice
John P in Ut
12-02-2001 11:55:14
I know someone discussed this before but I didn't have that problem yet. I just purchased a cockshutt 30 that has a froze/stuck engine. What is the best way to get the engine unstuck without tearing it apart? Or is there a way. I appreciate this forum as I also have a John Deere 50 and have learned alot from all you guys. thanks.
Bob
12-02-2001 14:18:55
 Re: Need some advice in reply to John P in Ut, 12-02-2001 11:55:14
Depending on how bad of shape it is in you can pour oil in the spark plug holes. Let it set for a few days and you should be able to rock the crank back and forth lossening it up. After you get it loose you will probably have to spray break clean in the cylinders to keep the oil from fouling the plugs when you want to start it.
Mike B
12-02-2001 16:12:03
 Re: Re: Need some advice in reply to Bob, 12-02-2001 14:18:55
I have the same idea as Bob except pour some Marvel Mystery Oil in the plug holes and let it sit for a while. That will penetrate better than plain oil and it will burn off easier and cleaner when you finally do start it.
Take your time and rock it by hand with a breaker bar and socket on the crankshaft pulley bolt 'till things are good and loose. Otherwise you can do a lot more harm than good and you'll certainly be breaking the engine apart.
Kevin
12-02-2001 18:13:09
 Re: Re: Re: Need some advice in reply to Mike B, 12-02-2001 16:12:03
The longer it sits with the Marvel the better. Resist the temptation to only wait a couple of hours. Give it a couple of days or even a week!
Canada Grant
12-02-2001 19:56:52
 Re: Re: Re: Re: Need some advice in reply to Kevin, 12-02-2001 18:13:09
Get the valve cover off ,and check that your valves are free . Tappet cover gaskets are cheap !
