5.9 cummins engines
John
11-30-2001 06:28:00
Shep, Putting these 5.9 cummins in these tractors for example do they bolt right into a 1855.
Shep..... I wish...
11-30-2001 10:11:25
 Re: 5.9 cummins engines in reply to John, 11-30-2001 06:28:00
No they sure dont, but they will fit given some time and patience. There are different ways you can install the Cummins in the tractor, for example you can use the existing frame in the 1855 but you have to cut out the engine mounts and cut part of the bottom of the tub frame out, or you can get an 1850 front frame and dont have to cut it at all. You can buy a kit from Cummins that has the engine mounts you need and most of the instructions for installing a Cummins in an Oliver, but I generally fabricate my own mounts and try to purchase engines a little cheaper than Cummins wants to sell you a new one for.
As with any repower of a tractor you have to do some fabricating to make everything fit correctly, and have some parts places that will work with you on finding parts, like finding radiator hoses that will work and such, but the work is well worth the results. It really does make a tremendous tractor when you are done. Here is a link to my photo album of the 1850 and the 1855 that I have converted to a cummins engine. Enjoy.
