Questions about 12 Volt alternator on an Oliver 77
Ross
11-27-2001 19:14:55
I put a 12 volt anternator on my 77 but it charges all the way over all the time which will burn up the alternator and the battery. The alternator is the type with 1 electrical post on the back and the 2 spade bits on the inside. Can someone tell me what wires go where? Thanks -Ross Boots
Jake
11-27-2001 21:37:52
 Re: Questions about 12 Volt alternator on an Oliver 77 in reply to Ross, 11-27-2001 19:14:55
The plug is available at any auto supply as alternator pig-tail. On my Olivers the red wire is connected to the alternator output and the white is connected to the ignition switch on run position to prevent draining the battery during perios of inactivity. A diode is available from Gennese[sp] systems. The converion is covered in the archives word search of Oliver 55 12 V conversion. It's worth a look at for information. Good luck
Jake
11-27-2001 22:10:02
 Re: Re: Questions about 12 Volt alternator on an Oliver 77 in reply to Jake, 11-27-2001 21:37:52
Look in the left side under "research and info", articles, then"Upgrading an Oliver Super 55 electrical system". It is a complete description of alternator and electronic ignition upgrade using the genisee prouucts.
Jake
11-27-2001 22:09:29
Gary M
11-27-2001 20:49:03
i have been converting tractors to 12v for years. if it is a Delco alternator, there are 2 types, self energizing and external regulated. if the terminals point out the back of the alt, its externally regulated, remove and toss it. if they point straight up, find a plug in the junkyard, and hook both wires to the + post on the back of the alternator. it will make the regulator run all the time, but its a tiny draw, and dont hurt anything. Run new 12ga or higher wire direct to the + battery terminal from the alt hot post. forget the amp gauge. if your using a heavy duty alternator, it will peg the amp gauge 90% of the time anyway, that old gauge was only made for 30 amps tops. only when its fully charged and idling will it read close to 0. DO NOT FORGET TO PUT A CHRYSLER IGN COIL BALLAST INLINE TO YOUR COIL!!
all the bulbs will blow out as soon as you turn them on, dash lights too. so replace them now. any primitive electromagnetic units may need protection as well.
